FINISHING SERVICES
Anodizing Services
ISO 9001
Real-Time Traceability
Machining & Finishing
Simplified Sourcing
Anodizing for Prototyping
and Production
Type II Anodizing
At A glance
Clear, black, red, blue, gold.
Smooth, matte finish. Does not cover machine marks unless media blasted beforehand.
Thickness
1.8 μm to 25 μm (0.00007")
Color Options
Anodizing Black
Black
Anodizing Clear
Clear
Anodizing Gold
Gold
Anodizing Red
Red
Anodizing Blue
Blue
Anodizing is an electrolytic passivation process that grows the natural oxide layer on aluminum parts for protection from wear and corrosion, as well as for cosmetic effects. It is a conversion coating, similar to Alodine, meaning that the surface of the aluminum recedes dimensionally before the protective oxide layer is built up. After the process is complete, the oxide layer is integral to the aluminum substrate below, which means it won’t chip or flake.
The name anodizing comes from the fact that the treated part forms an anode (positive electrode) in an electrical circuit. During this process, the part to be anodized is hung on a conductive rack and submerged in an electrolytic solution, where a direct current of electricity is introduced. While the acidity of the solution dissolves the oxide layer of the part, the electric current releases oxygen at its surface, which builds up a protective layer of aluminum oxide. By balancing dissolve rate with build-up rate, the oxide layer forms with nanopores, allowing continued growth of the coating beyond what is naturally possible.
The final steps of the anodizing process involve sealing the nanopores. Otherwise, they are the perfect passageways for corrosion initiation! Just before sealing, however, they are sometimes filled with other corrosion inhibitors or colored dyes for cosmetic purposes. After the process is complete, the coating will be 0.0002-0.0012” in thickness, in accordance with the common engineering spec MIL-A-8625 Type II.
Design considerations
  • Plugging threaded/reamed holes is not required unless tolerances are very tight, as thickness change is minimal. If you require specific areas to be masked or plugged, please make sure to include a drawing.
  • Parts without holes are hung on conductive racks with spring clamps, wire wrapping, or other methods, which will leave small areas without anodize known as ‘rack marks’. If there are areas on which you absolutely cannot accept rack marks, please make sure to include a drawing.
  • Anodizing has insulative properties, meaning anodized parts offer poor electrical conductivity.
  • Max part size for anodizing is 2438 x 762 x 1219 mm (96 x 30 x 48 in)
Type III Anodizing
At A glance
Clear (looks grey, with thicker coatings being darker), Black
Thickness
> 0.0005"
Type III Anodizing (commonly specified with MIL-A-8625 Type III in North America) is the same general process as Type II and provides similar benefits of increased resistance to wear, corrosion, and other general environmental effects. However, this type is also known as hard or hardcoat anodizing, as the protective oxide layer must be thicker than >= 0.0005”, with coatings up to 0.004” sometimes applied.
While the thicker coating of Type III offers greater physical protection to a part, it comes with some tradeoffs:
Increased Cost
Growing the oxide layer to a consistent and specified thickness requires far more process control than with Type II. This, in addition to the lower temperatures and much higher voltages needed to run the process, causes the cost of this process to be higher than Type II Anodizing.
Impact on Tolerances
A second tradeoff of Type III is the increased care that must be taken to ensure parts stay within specified tolerance. Type II thickness is minimal enough that most dimensions should remain similar after the process, but even the thinnest Type III can impact a tight tolerance on a reamed bore, render a threaded hole non-functional, etc. Therefore, plugging holes and masking sensitive surfaces is almost always employed with this type of anodizing.
  • This process adds substantial thickness to a part’s surface, so plugging and masking threaded/reamed holes or other critical-to-function surfaces is recommended.
  • Anodize has insulative properties, meaning anodized parts offer poor electrical conductivity.
Type III Anodizing with PTFE
At A glance
Black
Very smooth, matte finish. Does not cover machine marks unless media blasted before anodizing.
Can be applied with
Media blasting, tumbling
Anodizing Standards
*Type in Parenthesis
MIl-PRF-8625 (IA)
MIl-PRF-8625 (IB)
MIl-PRF-8625 (IC)
MIl-PRF-8625(II)
MIl-PRF-8625(III)
ASTM D1730
ASTM B580
SAE AMS2469J
AAMA 611-98 (A4)
AAMA 611-98(A3)
ASTM D3933-98
ASTM B580
Self-Serve Options on Platform
Standard Type Composition Application Examples
MIL-PRF-8625 Type II Sulfuric Acid Good for hardness and resistance to abrasion, such as optical components and hydraulic valve bodies
MIL-PRF-8625 Type III
(w/ PTFE available)
Sulfuric Acid (Hard Coat) Cookware; Good thermal resistance, electrical insulation, abrasion/wear resistance, and strong finish
Class Designations apply to Sealing: Class 1, non dyed; Class 2, dyed, color to be specified.
Available Through RFQ Only
ASTM D1730 Type 2, Method 1
(MIL-A-8625 equiv.)Zn
Sulfuric Acid Anodized finishes requiring dyeing, saltwater resistance, kitchen appliances
ASTM B580, type
A equiv to hard coat
AKA Type III Sulfuric Acid (Hard Coat) Cookware; Good thermal resistance, electrical insulation, abrasion/wear resistance, and strong finish
SAE AMS2469J equiv to
hard coat
AAMA 611-98 Class I (A4) Sulfuric Acid Aerospace parts requiring high performance architectural aluminum anodic coating; kitchen applicances
AAMA 611-98 Class II (A3) Sulfuric Acid General use commercial architectural anodic coating
ASTM D3933-98 N/A Phosphoric Acid Structural adhesive bonding; aerospace parts
ASTM B580 Type G (MIL-A-8625
Type I equiv.)
Chromic Acid Provides a good surface for paint and adhesive bonding
MIL-PRF-8625 Type IA Conventional Chromic Acid Paint primer for aerospace parts
MIL-PRF-8625 Type IB Low Voltage Chromic Acid Modified Type I used for 7XXX series aluminum alloys
MIL-PRF-8625 Type IC Non-Chromic
Acid Electrolyete
Improves paint adhesion and fatigue resistance
*May increase quote time, lead times, and costs
Standard Color Options
Black
Type II, Type III, Type III + PTFE
Natural
Type II, Type III
Gold
Type II
Red
Type II
Blue
Type II
*Custom colors available, upon request
What is Anodizing?
Anodizing is a conversion coating process that involves immersing aluminum into an acid electrolyte bath and passing an electric current through it. This creates a robust and fully integrated coating of aluminum oxide on the surface of the aluminum, replacing the naturally occurring oxide layer and penetrating through to the base metal. Unlike paint, anodizing doesn’t chip or flake.
Benefits of Anodizing:
Durability (wear resistance)
Abrasion resistance
Increased hardness
Corrosion protection
Cost-effective
Longevity
Desirable electrical properties
Skip the hassle of sourcing, vetting, and managing suppliers by seamlessly tapping into our fully-vetted, global supply chain of expert machining & finishing.
95.4%
Perfect order success rate
(on-time, in-full delivery)
Get Instant Quote
Coating Thickness vs Build-up
Part of the anodizing process is to remove the naturally occurring oxide layer, in a process called deoxidizing, by immersing the parts in an acidic solution. The electrochemically formed oxide layer is thicker than the naturally occurring oxide layer. Therefore, the build-up is actually less than the coating thickness, or the actual dimensional growth is less than the thickness of the anodized oxide layer.  Here are the terms commonly utilized in anodizing and you can see these in more detail in the image below:
Masking for Anodizing
Your parts may require masking, if you have tight tolerances on your threads or holes. This may even be applicable for a thinner, Type II MIl-PRF-8625 coating. Masking may be accomplished with plastic plugs, tape, or even painted-on liquid plastics. Masking should be called out on a drawing with notes. If you have questions about masking or plugging, contact one of our experts today.
Fictiv also offers other finishes for your machined parts, including:
Get a quote now
Learn More about CNC Machining
CNC Machining design guide
Rapid CNC Machining vs. Traditional CNC Machining
Read More >
PRECISION MACHINED PARTS
Precision Machined Parts: Fictiv's Comprehensive Guide
Read More >
TIPS FOR REDUCING CNC LEAD TIMES
Top 10 Design Tips for Reducing CNC Lead Time
Read More >
CNC machining involves far more than simply uploading a CAD model and cutting parts. Every part is shaped by the material, machine types, cutting tools, finishes, and design constraints that work together to determine cost, quality, and performance. To help engineers better understand these relationships, the Fictiv team created the CNC Periodic Table of Elements—a […]
