FINISHING SERVICES
Powder Coating
ISO 9001:2015 Certified
Real-Time Traceability
Full RAL color catalog
Simplified Sourcing
Powder Coating for Prototype and Production
At A glance
Pantone or RAL color matching
Finishes
See below for options
Can be applied with
Media blasting, tumbling (neither is needed)
Finish Options
Not all colors are available in the finishes shown above. Please contact us for availability
What is Powder Coating?
Powder coating is a process in which a dry powder paint (either a thermoplastic or thermoset polymer) is applied to a metal surface using electrostatic application. Unlike traditional liquid paint, powder coating does not need a solvent to keep the binder and filler of the paint in liquid suspension. This allows for application of thicker coatings without running or sagging, and the coatings are also tougher as a result.
The powder coating process starts off by electrically grounding the part to be painted, which gives it a net negative charge. After grounding, the paint is sprayed at the part using a corona gun, which applies a positive charge to the powder. The polarization of the two components causes the powder to stick to the metal, where it will remain so long as it is undisturbed.
After the powder has reached a specified thickness on the part, it is cured into a polymeric film using elevated temperatures (*200″C), such as with a convection oven. Thermosetting, polymers will crosslink during the curing process to improve performance, but thermoplastic varieties simply flow while heated to form the final coating.
Precision Powder Coating for Unmatched Performance
  • Production-Grade Quality Inspection of finished surface
  • On-Demand Inspection Report
95.4%
Perfect Order Success rate
(On-time, in full delivery)
Get Instant Quote
