Finishing Services
Hand Polishing
N/A
Applications
Enhanced cosmetic appearance
Smooth and glossy
Hand polishing is a manual process where the part is sanded, then buffed on a set of abrasive wheels or rouges to achieve the desired surface finish. This is a subtractive process that removes material in order to eliminate scratches and other imperfections.
Design considerations
  • Radiused corners and edges generally produce better results than sharp ones
  • Wall thicknesses less than 1.5mm do not hold up as well during polishing
  • Internal or hard to reach features (including threads) are difficult or impossible to polish
  • Very tight tolerances, reamed holes, and threads may need to be excluded from polishing
4-Axis CNC Machining: Capabilities, Applications, and Design Guidelines
4-axis CNC machining is a subtractive manufacturing process that moves a cutting tool and workpiece along four axes of motion—the standard X, Y, and Z linear axes, plus a fourth rotational axis (the A-axis) that rotates the workpiece around the X-axis. That additional degree of freedom is what separates 4-axis from conventional 3-axis machining. The […]
3-Axis CNC Machining Guide: Capabilities, Limitations, and Use Cases
3-axis CNC machining is a manufacturing process in which cutting tools move along three linear axes (X, Y, and Z) to remove material from a workpiece. It’s the most common type of CNC machining, ideal for producing simple to moderately complex parts with flat surfaces, pockets, and basic contours. 3-axis CNC machining is a powerful, […]
