Finishing Services
Black Oxide
Black
Smooth, matte black
Can be applied with
Media blasting, tumbling, passivation
Black oxide is a conversion coating (similar to Chem film) that is used for steel and stainless steel. It is used mainly for appearance and for mild corrosion resistance. Black oxide impregnated with oil can provide the highest amount of corrosion resistance. Black oxide is formed in a process similar to anodizing, where the parts are dipped into various hot baths of chemicals that convert the surface of the material into magnetite, which creates the black color. Black oxide does not have a significant dimensional impact, therefore masking parts is not necessary. This process can take a longer time due to the manual labor required and the time it takes for the baths to come to the correct temperature.
4-Axis CNC Machining: Capabilities, Applications, and Design Guidelines
4-axis CNC machining is a subtractive manufacturing process that moves a cutting tool and workpiece along four axes of motion—the standard X, Y, and Z linear axes, plus a fourth rotational axis (the A-axis) that rotates the workpiece around the X-axis. That additional degree of freedom is what separates 4-axis from conventional 3-axis machining. The […]
3-Axis CNC Machining Guide: Capabilities, Limitations, and Use Cases
3-axis CNC machining is a manufacturing process in which cutting tools move along three linear axes (X, Y, and Z) to remove material from a workpiece. It’s the most common type of CNC machining, ideal for producing simple to moderately complex parts with flat surfaces, pockets, and basic contours. 3-axis CNC machining is a powerful, […]
