Finishing Services
Electroless Nickel Plating
n/a
Smooth, glossy finish
Can be applied with
Alodine
Electroless nickel plating (ENP of NiP) is a reaction that deposits a nickel-phosphorus alloy onto the surface of a metal. It uses a purely chemical reaction to induce plating and does not leverage electricity. Though this process takes much longer than electroplating, advantages are a more uniform thickness over even the most complex surfaces (due to not having to rely on varying electric fields), as well as superior wear and corrosion resistance. The standard specification for ENP in North America is MIL-C-26074E, with various grades specifying thicknesses from 0.0003-0.002”.
Design considerations
Our standard offering for ENP adds thickness between 0.0003”-0.0005”, although we can achieve 0.00005” up to 0.002″ if specified in a drawing.
4-Axis CNC Machining: Capabilities, Applications, and Design Guidelines
4-axis CNC machining is a subtractive manufacturing process that moves a cutting tool and workpiece along four axes of motion—the standard X, Y, and Z linear axes, plus a fourth rotational axis (the A-axis) that rotates the workpiece around the X-axis. That additional degree of freedom is what separates 4-axis from conventional 3-axis machining. The […]
3-Axis CNC Machining Guide: Capabilities, Limitations, and Use Cases
3-axis CNC machining is a manufacturing process in which cutting tools move along three linear axes (X, Y, and Z) to remove material from a workpiece. It’s the most common type of CNC machining, ideal for producing simple to moderately complex parts with flat surfaces, pockets, and basic contours. 3-axis CNC machining is a powerful, […]
