Finishing Services
Zinc Plating
Clear: light blue coating; Black: glossy black coating
Smooth finish, does not hide machine marks
Can be applied with
Media Blasting, Tumbling, Passivation
Color Options
Zinc Plating Black Zinc Plating
Black Zinc Plating
Zinc Plating Clear Zinc Aluminum
Clear Zinc Aluminum
Zinc plating, which is also known as galvanization, is applied to prevent the surface from oxidizing or corroding. This process is done by coating the part in a flux and dipping the part into molten zinc. The molten zinc forms a bond with the steel, creating a protective layer on the surface of the part.
3-Axis CNC Machining Guide: Capabilities, Limitations, and Use Cases
3-axis CNC machining is a manufacturing process in which cutting tools move along three linear axes (X, Y, and Z) to remove material from a workpiece. It’s the most common type of CNC machining, ideal for producing simple to moderately complex parts with flat surfaces, pockets, and basic contours. 3-axis CNC machining is a powerful, […]
Scaling CNC to Casting Guide
How to Transition from CNC Machining to Casting for Production Scale Identifying the Right Parts for Casting CNC vs. Casting: Fundamental Differences Casting Process Selection (DFM) Design Adjustments for Transitioning from CNC to Casting Casting Design for Manufacturability (DFM) Considerations Materials & Performance Considerations Hybrid Strategy: Casting + CNC Finishing Simulation & Validation Tooling & […]
