CAPABILITIES
Die Casting Services
Fictiv’s die-casting offerings provide high-quality, precision-engineered castings with exceptional dimensional accuracy and surface finish. These castings reduce post-processing and improve interoperability, leading to faster production and lower costs.
4,100+ materials, process, and finishing options
round check mark
ISO 9001:2015
Certified
round check mark
Samples as fast as
10-15 days
round check mark
Technical support on design
and manufacturing
round check mark
Robust quality control
and testing procedures
Why Fictiv for Die Casting
High-precision metal parts with integrated post-processing and full-BOM support.
T1 Samples As Fast As 10 Days
  • Tight Tolerances as Low as +/- 0.003”
  • Full-BOM Services Including Welding, Installation, & Assembly
  • Ideal for Bulky, Complex, or High-Volume Parts
  • No Minimum Order Quantity
  • Post-Casting CNC Machining for Final Features
  • Finishing Options: Chem Film, Anodizing, Plating, Powder Coat
  • Inspection Reports With Every Order
  • Certified Aluminum, Zinc, and Magnesium Alloys
Die Casting at Fictiv:
Fictiv offers precision components, sustainable practices, and scalable solutions for diverse industries. We’re your trusted partner for innovative product development and cost-efficient manufacturing.
Up to 2500 x 3500 mm, with single-block weights of up to 20 tons
Auto degassing and melting towers for molten metal purity
Vacuum Casting and Density Index Control to manage porosity
Fictiv Die Casting Capabilities
Lead Time:
Sample parts as fast as 10-15 days.
Tooling:
Made from H13 hardened steel.
Tolerances:
+/- 0.1 mm per 25 mm for raw casting & +/- 0.05 mm for post-CNC machined features
Rapid Prototyping:
3D-printed wax patterns for quick-cast tooling
3D Scanning:
for rapid design validation or reverse engineering
WORKFLOW AUTOMATION
Fictiv's platform offers a vast range of process, material, and finish combinations. Here are some of the most commonly used options by our customers in the die-casting industry:
Download our Die Casting Design Guide
Learn our top tips for design, material selection, geometric features, tolerance, and more.
Download
Fictiv offers the equipment and processes to handle all your CNC machining needs after die casting. Sometimes a part requires clean up or detailed features to be machined post-casting. With our guided expertise, you can select which features should be cast versus machined. Mold flow analysis and industry-leading design software ensure the project will result in high quality die cast parts. Here are some of the post-die-casting CNC machining options Fictiv offers:
5-axis machining centers for complex geometries
Wire EDM and Graphite machining centers for fine details
Reliable Die Casting Quality
Fictiv’s commitment to maintaining rigorous appearance standards and rejection criteria ensures the final product consistently meets customer expectations. By specifying surface roughness in Ra and Rz values and adhering to clearly defined visual inspection protocols, Fictiv enables customers to have a thorough understanding of what to expect from their castings, further enhancing the collaborative process.
Testing and compliance includes: CMM, RoHS compliance, material composition testing (with XRF spectrometer), x-ray testing, salt spray testing, and hardness testing.
High vs Low Pressure Die Casting
Low Pressure Die Casting VS High Pressure Die Casting
Typically 5-30 PSI Injection Pressure Typically 1,000-20,000 PSI
Slow Injection Speed Comparatively Fast
Faster Cooling Rate
Lower Secondary Dendrite
Arm Spacing
>0.18 inches Recommended Wall
Thickness Range
0.08 to 0.16 inches
Higher Dimensional Accuracy?
Yes Undercuts? No
Better Suited for Complex Geometries?
Prototype Die Casting
T1 Samples As Quick As 10 Days
High quality parts done fast, per your design,
and to print tolerances.
Easy to Use Manufacturing Platform
Expert support from design to molding and
engineering changes
Guided Expertise
We have the skillset and experience for DFM and Prototyping process selection.
die casting mchel case study collage
Production Die Casting
production die casting part
Cost Down Analysis
We partner with you to do cost down analysis to meet
your requirements. Our global network enables Fictiv to optimize for "landed costs" of the product.
Dedicated Global Team
Manufacturing Engineers, Technical Program Mgt, SQE, Tooling Engineers, Logistics Supervisors assigned to each production program.
Complete Quality Systems
APQP full program planning, PPAP, Scientific Molding, Tooling inspection, and Automation.
Talk To The Team Learn More
Joe Tedesco
JOE TEDESCHO
Lead Aerospace Engineer
Heliospace
Download Case Study >
ANDREW WILLING
Mechanical Engineer
HEBI Robotics
Get a quote now
Learn More About Die Casting
ARTICLE
Metal Casting Defects: Types, Causes, and How to Prevent Them
Casting enables the efficient production of complex metal parts, but it also introduces a distinct set of quality challenges. Unlike…
Read more >
ARTICLE
CNC vs Die Casting Qualification Scorecard
Quick Evaluation Tool for Process Selection Compare die casting and CNC machining to determine the best process for your prototyping…
Read more >
ARTICLE
High-Pressure Engineering in a Small Form Factor The Breville Bambino Plus compresses key espresso machine architectures—thermal management, pump-driven pressure control,…
Read more >
Talk to Our Team
send button
Contact Us
